Rustyfoxx's avatar
Rustyfoxx
Follower
Apr 18, 2019
Need help connecting
I keep getting this same message when I try To connect to the WiFi router for the first time so I can finish the setup process. Keeps saying error opening page
  • plemans's avatar
    Little more info needed.
    1. it looks like you're trying to activate a modem from the activate.suddenlink.com webpage. Am I looking at this wrong?
    2. What modem is it? Firmware on the modem?
    3. Have you ever activated the modem?
    4. Have you tried setting up the R8000 over a hardwired connection?
    5. What firmware is on the R8000?
  • plemans's avatar
    One the modem is activated follow this procedure.
    1. Power on modem. Wait a couple minutes for it to fully boot and connect
    2. Plug router into modem. Power it on. Leave it for a couple minutes to fully boot.
    3. Plug into router or connect to router to do setup. Always recommend hardwiring in for setup/activation.
    does it work?
