Anay0810's avatar
Anay0810
Follower
Jan 06, 2020
Need help with connecting phone line to RAX120
Hi,
I was wondering if there is any way to connect a telehone to the RAX120 router.
This has 4 RJ45 networking ports. Would it help if I use an adaptor to convert RJ11 into an RJ45 and then connect it to the router?
  • Anay0810 wrote:
    Hi,
    Why do you want to connect a phone to the RAX120? What are you attempting to do here? The RAX120 is not a dsl modem and doesn't have DECT built into it.
    If you want you can make an adapter but it isn't going to do anything other than maybe wreck your router.
    If you want to connect a phone to a router you need something like a voip setup or a router designed for phone service.
1 Reply
  • plemans's avatar
    Anay0810 wrote:
    Hi,
