Ford8725's avatar
Ford8725
Follower
Nov 24, 2020
Need part number for a/c adapter for AX4300
n/a
  • plemans's avatar
    AX4300 is a speed, not a model.
    Do you have the old adapter?
    Netgear doesn't sell power adapters so usually you have to buy one with matching capabilities 3rd party or from ebay.
  • michaelkenward's avatar
    michaelkenward
    Netgear does not sell replacement power adapters. Any generic adapter will work, as long as it has the right volts, enough amps and a tip with the right (+/-) polarity and dimensions.
    Look at the device you own. It will have a label that shows what you need.
    The manual will have the information too.
    Plug the details into your favourite on-line store, or visit a local shop.
