plz_respond123's avatar
Feb 19, 2021
Need to buy power adapter for my router
I need help in buying power adapter for my router.
I lost mine when I moved.
I live in Japan and bought mine at Amazon Japan so if anyone could link me an amazon.co.jp link of power adapter that is compatible with my router, that will be a huge help.
For reference this is the one I bought:
https://www.amazon.co.jp/-/en/gp/product/B07S74RMZP
Thank you so much.
    • antinode's avatar
      antinode
      Guru
      > Model: RAX120|Nighthawk AX12 12-Stream WiFi Router
         Visit http://netgear.com/support , put in your (actual) model number,
      and look for Documentation.  Get the User Manual.  Read.  Look for
      "Technical Specifications" and "Power adapter".  Then look for something
      with the desired ratings and connectors.
      • antinode's avatar
        antinode
        Guru
            You might also check the ratings in the manual against the ratings
        printed on the product label.
  • There's like million variation on how the tip of power adapter looks like. I bought 2 already that doesn't fit. I found some kind of convert (30+ types), hope atleast one of this works.
