Valcugen's avatar
Valcugen
Initiate
Jan 21, 2021
Netgear AX12 RAX120 EU type plug
Hello,
I would like to ask, where can i find a replacement adapter, i have purchased the router in the US while i was there for a business trip but i apparently have missplaced the adapter and now i that i came back in Bulgaria and i am unable to use it since the voltage is 220 here.
Thank you very much in advance!
  • Netgear doesn't sell replacement power supplies. But you can use a 3rd party adapter. Just make sure it has the same output voltage, at least the same amperage (can be higher), and the same polarity.
  • plemans's avatar
    • Valcugen's avatar
      Valcugen
      Initiate
      From what i saw over the internet, i can get my hands on a US version 9v 3.16a and just use a US to EU adapter since from what i can see the US powerbrick is 100-220v, so just using a "tourist" adapter without any voltage converter will do the trick.
