Rob_B71's avatar
Rob_B71
Follower
May 03, 2025
NETGEAR AX120 Router w/Bitdefender service
I have this router, and I also have the Bitdefender service for security w/VPN. I have noticed that the router does not have the VPN service running on it. I am wanting to get this VPN service on it, but it shows the only VPN service on this router is that is compatible is something called PureVPN. I do not know this service, and I have already paid for a VPN service I want to use on my home router. Does anyone know how I can get around this other service to get the current VPN running. Thanks in advance for any assist.
1 Reply
  • Most home routers don't support any VPN installation features. Most VPN are services that pass thru the router. You'll need to make contact with the desired VPN service to see how to setup and use there VPN services.
    Good Luck.
