mpatel478
Mar 24, 2022Aspirant
Netgear AX6 AX5200 slow Wifi connections
Router is Netgear Nighthawk AX6 AX6 AX5200 6-Stream wifi router Model: RAX48 Below are my router settings. I am having issues with multiple devices (laptops, phones, tablets, tv, etc...) Speed ...
Mar 24, 2022Guru - Experienced User
Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 or 149 channel on 5Ghz.
What happens if Smart Connect and MIMO are enabled?
Is Armor, SPC or Traffic Meter enabled?
- mpatel478Mar 24, 2022AspirantI did the firmware update just few days ago. So it’s up to speed. Although it doesn’t tell me the latest version number but when I check for latest version it says it’s up to date.
Armor, SPC or Traffic Meter Are not enabled. Mimo didn’t work too well but I will test this out and see how it does. Same with smart connection same problems. So I separated them out. I selected the channel you recommended on both wireless 2.4 and 5g. Will update and see how it goes next day or so. Thanks- FURRYe38Mar 24, 2022Guru - Experienced User
You can find the FW version on the RAX web page.
- mpatel478Mar 30, 2022Aspirant
I changed the channel on 2.4ghz to channel 11 and it seems to be better. Still getting slowness with videos but less. The 5ghz is also better but I need to run more tests. It seems to behave good when only couple of devices are online but soon as the number of devices go up then the slowness starts. I will post another update after some more testing.
