mpatel478
Mar 24, 2022Aspirant
Netgear AX6 AX5200 slow Wifi connections
Router is Netgear Nighthawk AX6 AX6 AX5200 6-Stream wifi router Model: RAX48 Below are my router settings. I am having issues with multiple devices (laptops, phones, tablets, tv, etc...) Speed ...
Mar 24, 2022Guru - Experienced User
Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 or 149 channel on 5Ghz.
What happens if Smart Connect and MIMO are enabled?
Is Armor, SPC or Traffic Meter enabled?
mpatel478
I did the firmware update just few days ago. So it’s up to speed. Although it doesn’t tell me the latest version number but when I check for latest version it says it’s up to date.
Armor, SPC or Traffic Meter Are not enabled. Mimo didn’t work too well but I will test this out and see how it does. Same with smart connection same problems. So I separated them out. I selected the channel you recommended on both wireless 2.4 and 5g. Will update and see how it goes next day or so. Thanks
- FURRYe38Mar 24, 2022Guru - Experienced User
You can find the FW version on the RAX web page.
