mayeen12
Apr 12, 2020Star
NETGEAR AX8 / RAX80 WAN/Internet Throttled - AVOID BUYING
My Router: Nighthawk RAX80 Firm V1.0.2.76_1.0.35
Internet: Cable 940 MBPS - I constantly get 940+ mbps when my PC is connected directly to CABLE MODEM
Devices; 15-20
I'm annoyed beyond believe - i purchased by router Dec 2019 - 500 CAD$
This router has mind of its own for the WAN PORT.
There is countless people reporting this, I found this problem from the day i purchased it.
If only i had known, i would have returned it than, back than i asssumed it was my internet being throttled by ISP
What happens is, the router is run for 1h at full speed wan, than starts throttling to 360 MBPS - wifi or wired. with QOS ON
Than if i turn off my QOS, speed goes up to 480 mbps.
THan if i trun back my QOS, speed goes up to 950+ mbps for few hours. until router starts throttling again.
Everything else - wifi speed, AX speed 800+ mbps over wifi, internet network. WORKS PERFECLTY --
GOD DAM WAN is ONLY porblem only if you have Gigabit connection.
THE DAMM TECH at netgear are bunch of jockers with their MTU settings and stuff..
I wish i had returned it
I finally fixed my problem
Final Results, I'm getting FULL 940 to 985 MBPS download (From Internet & Internal NAS Drive) - both in wired and wifi mode.
PLEASE NOTE** All my clients are wired or AC or AX devices.
Step 1 - Get the latestest firmware
Step 2 - Turn OFF QOS
Step 3 - Turn OFF Traffic Meter
Step 4 - Turn OFF Access Control
Step 5 - Test you MTU with your MODEM from a wired connection MODEM <> PC > https://kb.netgear.com/19863/Ping-Test-to-determine-Optimal-MTU-Size-on-Router
Step 6 - Adjust your MTU settings >> https://kb.netgear.com/24015/How-do-I-change-the-MTU-size-on-my-Nighthawk-router
Step 7 - Use WiFI Analizer - FIND THE BEST CH for WiFI - I put AUTO for 2.4 and CH36 for 5ghz
Step 8 - ENABLE BEAMFORMING > DISABLE MUMIMO > ENABLE AX
mayeen12 wrote:My Router: Nighthawk RAX80 Firm V1.0.2.76_1.0.35
Devices; 15-20
GOD DAM WAN is ONLY porblem only if you have Gigabit connection.THE DAMM TECH at netgear are bunch of jockers with their MTU settings and stuff..
Make and model of that modem?
Technicolor TC4400
Funny looking beast. Looks like modem only. No routering. But two LAN ports? Alien country to me.
Devices; 15-20
