bigbarthy
Jan 24, 2020Tutor
Netgear Genie app
Netgear Genie App is still way too small. If it's fixed, I cannot locate it.
- DarrenMSr. NETGEAR Moderator
What router do you have? Have you tried using the Nighthawk app?
DarrenM
- I have the nighthawk app on my phone. Genie on my laptop. I know I can get in there thru the web using op number, just like the convenience of the app
I have an AX4
bigbarthy wrote:Netgear Genie App is still way too small. If it's fixed, I cannot locate it.
Assume you talk of a Windows desktop Genie "App" operating on a high density display. - look here: Netgear Genie Window to small in Windows 10 -- UPDATE
Enjoy!
Are you talking about the screen resolution of the desktop genie on a Windows PC?
Which version of the genie do you have installed?
