Jimmsy
Sep 13, 2024Follower
Netgear model rax29
I am trying to see if my router is compatible with a wifi connection and they need the imei number and I;ve spent the past 2 hours trying to find it. Does anyone have any suggestions/answers? Thank you
IMEI number doesn't effect WiFi or compatibility with wifi routers. That number associates the phone or pad to a cell phone service provider.
Make contact with the Mfr of the phone or pad or cell service provide on how to find the IMEI number. Usually found in the ABOUT section of the device.
what do you mean by this?
Details are key. Explaning what you're doing, why you're doing it, and what devices you have that you're connecting them to is critical. What "wifi connection" are you attempting to connect the RAX to?
