BostonRob777
Feb 20, 2022Tutor
Netgear Nighthawk App - all my options are gone
For whatever reason I lost all of the options on the home screen of the netgear nighthawk app. Parent controls (Circle), traffic meters, all are gone. I have no idea why.
I tried uploading the latest firmware to the router.
Deleting and installing back the app.
Hard resetting the router
Nothing works.
I have the RAX200 Nighthawk AX12
Problem solved. I unchecked "enable AP Mode"
All the features in the App are now present.
This was from the user guide.
Set up the router as a WiFi access point
You can set up the router to run as an access point (AP) on the same local network as another router.
To set up the router as an AP:
UseanEthernetcabletoconnecttheInternetportofthisroutertoanEthernetport on the other router.
Launchawebbrowserfromacomputerormobiledevicethatisconnectedtothe router network.
Enterhttp://www.routerlogin.net. A login window opens.
Manage Network Settings 80 User Manual
Nighthawk Tri-Band AX12 12-Stream AX WiFi Router
Entertherouteradminusernameandpassword.
The user name is admin. The password is the one that you specified the first time that you logged in. The user name and password are case-sensitive.
The BASIC Home page displays.
SelectADVANCED>AdvancedSetup>WirelessAP. The Wireless AP page displays.
SelecttheEnableAPModecheckbox.
Netgear has set up a community forum specifically for the Nighthawk App product. Most of the people who watch that forum are more likely to have experience with Nighthawk App. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-App/bd-p/en-home-networking-apps
Thank you.Problem solved. I unchecked "enable AP Mode"
