manihatan
Nov 21, 2022Follower
Netgear RAX20 problem
Yesterday my router disconnected and it hasn’t been back on for nearly 24 hours. The lights are stuck on, Power LED - solid white Internet LED -solid amber Wifi LED -solid white. That’s it. Tried u...
Nov 21, 2022Guru - Experienced User
Is the wifi broadcasting?
Do devices connect to the router but say "connected, no internet"
What modem/gateway is the router connected to?
Did you try a factory reset and reinstall?
