kuki68ster
Sep 01, 2020Follower
Netgear RAX20 voltage
Hello,
I recently bought a netgear RAX20 from the US and it came with a 100/120v charger...Can anyone tell me if the router is compatible with a 220/240v charger? Thanks
- Christian_RNETGEAR Employee Retired
Hello kuki68ster,
We recommend that the device is used in the country it was purchased from.
Christian
I have used several Netgear 100/120v adapters in the UK. Not one has gone bang.
But you can use any suitable adapter with the right output.
I should have added that you may have a hard time getting a US device to play nicely with European wifi standards. Come back if you hit that brick wall.
