soniccatboy's avatar
soniccatboy
netgear rax200
Hello to all
i have a question regarding netgear rax200 is it still safe to use. i purchsed it via amazon and trying to setup router i noticed netgear uk doesnt sell it anymore in united kingdom, it updated to latest firmware upo setting it up. works on my broadband perfect bt jusy had concerns if its still getting software updates in uk please
  • Hello and thank you all so much for taking the time to reply i finally head back from netgear regarding rax200 eol dates pasted thank you so much once again thankful i still got a little time til end of dec for uk, can start saving now for another router
    RAX200RAX200-100PRS13/12/202113/12/2021The product reached EOS on 13-DEC-2021. We encourage you to replace your device with a newer NETGEAR device.
    RAX200RAX200-100AUS15/07/202415/07/2027The product is scheduled to reach EOS on 15-JUL-2027. We encourage you to replace your device with a newer NETGEAR device before it reaches EOS.
    RAX200RAX200-100EUS01/12/202301/12/2026The product is scheduled to reach EOS on 01-DEC-2026. We encourage you to replace your device with a newer NETGEAR device before it reaches EOS.
    RAX200RAX200-100NAS01/12/202301/12/2026The product is scheduled to reach EOS on 01-DEC-2026. We encourage you to replace your device with a newer NETGEAR device before it reaches EOS.
    RAX200RAX200-100JPS15/04/202315/04/2026The product is scheduled to reach EOS on 15-APR-2026. We encourage you to replace your device with a newer NETGEAR device before it reaches EOS.
    RAX200RAX200-100KOS15/06/202215/06/2022The product reached EOS on 15-JUN-2022. We encourage you to replace your device with a newer NETGEAR device.
    RAX200RAX200-100CNS01/01/202501/01/2028The product is scheduled to reach EOS on 01-JAN-2028. We encourage you to replace your device with a newer NETGEAR device before it reaches EOS.
  • plemans's avatar
    Its still safe. I have a RAX200 and got the same "End of life" email on it. The list probably isn't updated yet.
    Plenty of devices are EOL and still work great. They just aren't going to be getting updates any longer.
  • FURRYe38's avatar
    Yes. Still safe and good to use. If it's working, don't fix it.
