kiwisbrown
Mar 29, 2023Aspirant
Netgear RAX43 - No Errors, Ethernet Works Fine, Wifi has no internet
This is an odd one. The router is on the latest firmware. Ethernet is working great, but devices connected via wifi periodically have no internet connectivity. Rebooting the router fixes it for 3 - ...
- Mar 29, 2023
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
kiwisbrown
problem is solved
Mar 29, 2023Guru - Experienced User
What solved the problem?
