jasmimuse
Oct 31, 2023Follower
Netgear RAX45 can't change IP for LAN network
Logged into my router (Netgear RAX45) to change my home IP scheme because it conflicts with my work IP scheme...except it won't change. To anything. It just reboots and comes right back with the same...
michaelkenward
Oct 31, 2023Guru - Experienced User
jasmimuse wrote:
Logged into my router (Netgear RAX45) to change my home IP scheme because it conflicts with my work IP scheme...except it won't change. To anything. It just reboots and comes right back with the same IP it had before I changed it.
How can your home system conflict with the work system?
Are they connected?
What "IP scheme" is this?
What are you changing?
Where are you changing it?
