sktn77a
Jul 17, 2026Virtuoso
Netgear router range
Looking at getting a new router and am leaning towards a current Netgear model. I see you go up in the model series (in price and speed) and the range supposedly increases from ~2000 sq ft to ~3500s...
HappyCat
sktn77a wrote:or do their more expensive routers actually have more range
On the Pro series products, Netgear often publishes "maps" of coverage***. (something we do not see with residential products.)
Given that the WiFi coverage is roughly circular, 2000 sq. ft. corresponds to a radius of about 25 ft. 3500 sq. ft. corresponds to about 33 ft. So, the marketing literature is claiming that you will get a strong signal about 8 ft. farther away from the expensive router than from the less costly router.
Who knows? It could be that the more expensive router has a more expensive antenna.
*** Here's a random example:
sktn77a
HappyCat wrote:Who knows? It could be that the more expensive router has a more expensive antenna.
What constitutes a "more expensive" antenna - is there such a thing in a router?
- HappyCatJul 17, 2026Virtuoso
Good question. WAY beyond my competence level. Notice this comment in the RS500 Product technical specifications:
RS700:
- sktn77aJul 18, 2026Virtuoso
Yeah, beyond my expertise, too. The FCC limits all wifi routers to a maximum power level so they are all the same in that regard (you can reduce the power on some but you can't increase it). That leaves the antenna system but for an omnidirectional signal distribution (as opposed to "beamforming") I don't know there's much you can do inside those boxes(?)
