spinrite67's avatar
spinrite67
Follower
Mar 20, 2024
NETGEAR Router RAXE300 no wifi 6E for One Plus 12 device
I can't seem to get my one plus 12 smartphone to pickup in the wifi settings of the phone to get SSID wifi name that I created. It won't sleep in the wifi list on the OP12 now matter what settings I change. Any insights?
  • FURRYe38's avatar
    Check with the Mfr of the phone device for help and information regarding there product.
    Is this the only device that has this problem?
    How is the router configured for wifi?
  • michaelkenward's avatar
    michaelkenward
    What does "no wifi 6E" mean?
    One Plus 12 can't connect to the RAXE300? No 6GHz?
    When only one wifi client has problems, it isn't likely that the wifi source is the problem. Look to the client, your One Plus 12 device.
    I do not understand "won't sleep in the wifi list", but the first thing to try it so tell the phone to forget that it ever connected to the RAXE300 and to recreate the connection.
