Automation13
Aug 03, 2025Aspirant
Netgear Router Suggestion for Fritzbox 7530.
Hi, can anyone please suggest a home router that is compatible with an existing Netgear EAX 20 used as WIFI extender? The router does not need to have more than one Ethernet port and must be fully co...
Aug 03, 2025Guru - Experienced User
you should be able to connect the eax to the fritzbox. What issue are you having setting it up?
