Automation13
Aug 03, 2025Aspirant
Netgear Router Suggestion for Fritzbox 7530.
Hi, can anyone please suggest a home router that is compatible with an existing Netgear EAX 20 used as WIFI extender? The router does not need to have more than one Ethernet port and must be fully co...
Automation13
Aug 11, 2025Aspirant
Didn`t help. I off to buy network equipment from someone that can support their devices.
Aug 11, 2025Guru - Experienced User
Where do you see that NG doesn't support there devices?
