FURRYe38's avatar
May 14, 2022
New - RAX20/38v2 Firmware Version 1.0.11.112 Released
Bug Fixes
  • Fixes the issue where Advanced Tab cannot function when using Safari Browser.
  • Fixes the issue where QoS priority setting cannot be saved after enable QoS.
  • Fixes the issue where DHCP reservation cannot support maximum 253 IP addresses.
  • Fixes minor bugs.
Firmware Update Instructions
Download Link:
RAX20:
https://www.netgear.com/support/product/rax20.aspx#download
RAX38v2 only:
https://www.netgear.com/support/product/RAX38v2#download
RAX38v1 is not compatible.
To update your router’s firmware, follow the instructions in your router’s user manual. To view your router’s user manual, visit https://www.netgear.com/support/product/RAX20.aspx#docs.
https://www.netgear.com/support/product/RAX38v2.aspx#docs.
Manually update router FW:
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
NOTE: A factory reset and setup from scratch maybe needed if problems are encountered after applying FW updates:
https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router
NOTE: Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
This article applies to:
Wireless AX Router Nighthawk (WiFi 6) (1)
RAX20
Let us know how it works for you in this thread...
