FURRYe38's avatar
New - RAX41/42/43/50/54 V2 Firmware Version 1.1.3.18 Released
New Features: 12/13/2022
  • Include China gaming feature XunYou promotion pop-out window
Bug Fixes:
  • Fixes the issue where the AP mode cannot forward multicast packet issue
  • Fixes the issue where the AP mode missing Web Service Management feature
  • Fixes the issue where region name didn’t display on Router Status page after selecting to region Hong Kong.
  • Fixes the issue where 20/40MHz co-existence cannot auto switch back to 40MHz.
  • Fixes the issue where Guest Network status didn’t sync to “Router Status” page
Security Fixes:
  • Addresses security vulnerabilities.
Download Links:
RAX41v2:https://www.netgear.com/support/product/rax41v2#download
RAX42v2: https://www.netgear.com/support/product/RAX42v2#download
RAX43v2: https://www.netgear.com/support/product/RAX43v2#download
RAX50v2: https://www.netgear.com/support/product/RAX50v2#download
RAX54Sv2: https://www.netgear.com/support/product/rax54sv2#download
To update your router’s firmware, follow the instructions in your router’s user manual.
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
NOTE: Nighthawk app or the routers web page may not report seeing new FW updates. NG may not push this to there auto update services immediately and may activate the newer FW update being seen on there auto update services at a later time. User will have the choice to manually update if you want too.
To Manually update FW on the router if this isn't seen on the routers web page:
NOTE: Use a wired PC and web browser to update router FW. If continued problems are seen after a FW update, it's recommended to try a factory reset and setup from scratch with out loading any saved configurations from backup files.
https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router
NOTE: Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200
This only supports v2 models:
Let us know how it works for you...Please leave feedback.
