FURRYe38's avatar
New - RAX70/78 Firmware Version 1.0.13.128 Released
New Features: 10/04/2022
  • Added Xunyou pop-up window for PR SKU
Enhancements:
  • Upgraded SPC agent to version 3.26.1.1
Security Fixes:
  • Addresses security vulnerabilities.
Firmware Update Instructions:
Download Links:
RAX70:
https://www.netgear.com/support/product/rax70.aspx#download
RAX78:
https://www.netgear.com/support/product/rax78.aspx#download
To update your router’s firmware, follow the instructions in your router’s user manual. To view your router’s user manual, visit https://www.netgear.com/support/product/RAX70.aspx#docs
Backup the routers configuration first:
Manually update FW on the router if this isn't seen on the routers web page: Recommended
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
NOTE:  A factory reset and setup from scratch maybe needed if problems are encountered after applying FW updates:
https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router
NOTE: Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
NOTE: Its recommended to install a USB laptop cooler under the router for 24/4 cooling. Helps keep the router cool and helps avoid heat damage to the electronics.
This article applies to:
Wireless AX Router Nighthawk (WiFi 6)
Let us know how it works for you...
