SAM_the_GAM
May 29, 2020Luminary
New Firmware Released RAX80 1.0.3.88
Bug Fixes: Fixes the issue where the wireless transmit power does not match the percentage set by the “Transmit Power Control” setting, which is on the of Advanced-Wireless-Settings page of the rou...
michaelkenward
May 30, 2020Guru - Experienced User
baileyj0611 wrote:
My RAX80 will NOT upgrade to this.
I'm afraid that "will NOT upgrade" doesn't help when trying to debug your problem.
What are you doing and what happens when you try?
baileyj0611
Jun 01, 2020Tutor
When the router tries to perform self update, it states no new firmwares available.
When I try to manually do it, it says the FW file is wrong and will not update.
This router is garbage.
- michaelkenwardJun 01, 2020Guru - Experienced User
This is usually a sign that someone is trying to apply firmware for a different device, that they have got a corrupt download file, or they are trying to upload the whole zipped download rather than the unpacked firmware bit.
- baileyj0611Jun 01, 2020Tutor
I am pushing only the chk file, redownloaded twice and tried.
guess i'll keep trying
- NmouneimneJun 01, 2020Apprentice
I think the last firmware that worked with network storage was 1.0.1.64. I had to downgrade to that version, and have not moved off that firmware because it had been the most stable for me.
Where can I find that download? Thanks.
MacauBBS from this forum posted it for me in this thread.
- pir4tedirkJun 06, 2020TutorNever had any problem with any drive (re)formatted to NTFS.
