SAM_the_GAM
May 29, 2020Luminary
New Firmware Released RAX80 1.0.3.88
Bug Fixes: Fixes the issue where the wireless transmit power does not match the percentage set by the “Transmit Power Control” setting, which is on the of Advanced-Wireless-Settings page of the rou...
baileyj0611
Jun 01, 2020Tutor
Where can I find that download? Thanks.
Nmouneimne
Jun 01, 2020Apprentice
MacauBBS from this forum posted it for me in this thread.
- SAM_the_GAMJun 01, 2020Luminary
After this firmware update it is important do a factory reset. I was still getting LAN disconnects after I upgraded from 1.0.2.76. Aftter factory reset LAN / WAN has not reset after 30 hours. I am checking the LAN/WAN uptime under statistics.
- FredAloneForEveJun 01, 2020Star
Hi everyone,
I have upgraded with .88 firmware.
If i check the WPA2+WPA3 box in the wifi settings page, I can't check the smart wifi box in the same time.
If I want the smart wifi feature, I have to stay in WPA2 security mode.
Is it the same for you?
