jpamix
Jan 14, 2020Aspirant
Nighthawk® X10 Smart WiFi Router and NIGHTHAWK TRI-BAND AX12 12-STREAM WIFI 6 ROUTER Model: RAX200 ?
Good morning, I liked a bad opinion of the community in relation, I am thinking of buying a netgear router but I would like to know your choice between Nighthawk® X10 Smart WiFi Router and NIGHTHAWK TRI-BAND AX12 12-STREAM WIFI 6 ROUTER
Model: RAX200, since both are a high price which one is better? thanks
HI jpamix,
Both routers are great! Key difference between the two routers is that the RAX200 supports WiFi 6 and the the R9000 does not. If you have devices that support WiFi 6, you may want to check out the RAX200.
Christian
- Christian_RNETGEAR Employee Retired
HI jpamix,
Christian
- jpamixAspirant
Thank you very much for your opinion.
I have Gigabit Fibe 1.5 internet package, I wonder if I take advantage of the 2.5 multi-gig ethetnet port featured on rax200 ?
