NightHawkUser8
Mar 27, 2020Aspirant
Nighthawk App Not Connecting After Firmware Update
Firmware got updated to V1.0.3.86 via notification through the app for my Nighthawk Mesh MK62. After updating, the Nighthawk app started to have horrible performance. It takes quite a while for it to...
- Apr 02, 2020
You may need to manually upgrade your FW.
Go to this link:
https://www.netgear.com/support/download/default.aspx
Enter MK62 in the equipment field.
additude
Apr 02, 2020Virtuoso
Go to this link:
- NightHawkUser8Apr 03, 2020Aspirant
Thanks. I updated the same version firmware manually and that seemed to have resolved the issues.
