w4wws
Dec 08, 2020Aspirant
Nighthawk Armor security- Nighthawk RAX120
Since I purchased the Armor security for my router it has locked out a device on my newtork. The device is a PI-STAR which i use for ham radio, so how can i get it unblocked to i can use the PI-Star on the WWW.
Thanks, Steve
- Christian_RNETGEAR Employee Retired
Hi w4wws,
Can you confirm that when you disable Armor you're able to access your device?
Christian
- w4wwsAspirant
No it still seems that it will not get to the world wide web. it worked before the armor was put on.
