terinsuke
Oct 24, 2023Follower
nighthawk ax12 rax 120
the 5g network would randomly omly disappear while 2.4g and needed power reset decided to update firmware and erase to factory and set up now i can’t connect to 5g netiekr but i can see it on iphon...
michaelkenward
Oct 25, 2023Guru - Experienced User
terinsuke wrote:
on iphone with correct passsword it always says unable to connect to network.
Try this:
NETGEAR Mobile Applications and Apple Devices FAQ - NETGEAR Communities
