Brillstone
Jun 26, 2020Aspirant
Nighthawk AX12
have a problem with the new router, when to use VPN and FTP?
Has opened ports for ftp and also started the VPn according to netgear's software.
When I try, all ports are closed and VPN does not work?
Also has UPnP in progress.
Is there anything else you should start to get ports open (have done just before on the netgear R8000 and there was no problem there)
Suggestions?
- Christian_RNETGEAR Employee Retired
Hi Brillstone,
I would suggest contacting our support team to assist with your setup.
https://www.netgear.com/support/default.aspx
Christian
- BrillstoneAspirant
It works now, it was my isp fiber switch that was the problem
Thanks
