Th3-0n3's avatar
Th3-0n3
Tutor
Dec 06, 2019
Nighthawk ax120 low wifi speed when i disable QoS any help?
guys I just got my Nighthawk ax120 to replace a nighthawk r7800 that was falling on me. When i Do the speed test on my pp that is connected by ethernet cable to the router I get almost the full gig of download speed that I pay For. If I run a wifi speed stest on the 5ghz i get over 500mbps. The problem is that when I go in to the router setings to disable the QoS both 2.4Ghz and 5Ghz wifi speed slow down to only 13mbps. Any help on how to solve this? Any body else having this problem?
The router is running the latest firmware ending in 108.
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    Hello Th3-0n3,
    I have sent you a message. Please check your inbox.
    Christian
    • Falcon3856's avatar
      Falcon3856
      Hi,
      I am having the same issue.
      What was the solution for this?
      Thanks for your help
      • Th3-0n3's avatar
        Th3-0n3
        Tutor
        sorry I ended up just leaving the thing enable. since I had school work to do.
