SASS678
Jun 27, 2019Aspirant
Nighthawk AX4 4-Stream WiFi 6 Router
I'm thinking of purchasing the model mentioned above. My previous two Netgear routers had "Readyshare". Can anyone on here tell me if this model has Readyshare??
- Jun 30, 2019
Thanks again, Here is what I found. It answers my question.
Will my USB drive work with ReadySHARE
All Routers should work with most USB-compliant external flash and hard drives. Do NOT connect computers, USB modems, CD or DVD drives to the router's USB port. Please...
Christian_R
Jun 28, 2019NETGEAR Employee Retired
Hello SASS678,
Readyshare is not a feature currently on the RAX40 but is something you can request over on the Idea exchange board using the link below.
https://community.netgear.com/t5/Idea-Exchange-For-Home/idb-p/idea-exchange-for-home
~Christian
SASS678
Jun 29, 2019Aspirant
Christian,
I notice there is a USB port on this model. Does it recognize a hard drive that is plugged into it? I have one plugged into my Nighthawk R7000 that I use to store all my information re Readyshare. I was wondering if or how the Nighthawk AX4 could be set up to continue the storage.
Jim
