arewe3's avatar
arewe3
Nighthawk AX4 in AP mode connect to XR300
I hope this is the correct place to post this.  I have a XR300 router.  I have connected it with a LAN cable to AX4 router that I setup in AP mode.  The XR300 will not connect to the AX4 router.  (My old setup was a spectrum router with AX4 in AP mode.  SSID and passwords are the exact same and it works great.)  When I switch out to the XR300 as my main router the LAN light on the XR300 blinks red every 5 or so seconds on the port I have connected the AX4.  When I put my old spectrum router back in place the AX4 router works great.  The cable distance is about 100 feet.  I brought the AX4 router next to the XR300 and connected it with a 6 foot cord and the LAN light light up white and seem to have connected.  Took it back to my outside building and connected it the light went back to red and the AX4 has no access.
I performed a factory reset on AX4 and the XR300.  Set AX4 backup as AP and XR300 as main router and the AX4 still did not work.  The SSID's and passwords are exactly the same.  Could this be a distance issue for the XR300?  Cat5e cable has a limit of about 300 feet but it works great with my spectrum router setup as my main router.  The XR300 is set to DHCP and everything else seems to work just fine when except I can't get it to see the AX4.
Thanks for any help
  • CrimpOn's avatar
    CrimpOn
    StephenB wrote:
    I don't know which X4 model you have
    There are several models which include AX4 as part of the description.
    • arewe3's avatar
      arewe3
      AX4:RX35 firmware Ver: 1.0.4.102_1.0.1 Hardware Ver R1.05
  • The Xr300 works and has internet connection.  All the wireless devices attach and work fine.  I have issues seeing color so I am going to assume the blinking light is amber and not red as I said before.  The cable goes from XR300 port #4  direct to port 4 on the AX4.  It is also the same cable the I use to connect the spectrum router to the AX4.
    • StephenB's avatar
      If the AX4 is in AP mode, then normally you'd connect the cable between an XR300 LAN and the AX4 WAN port.
      • arewe3's avatar
        arewe3
        Yes, it is connected from XR300 LAN port 4 to AX4 (in AP Mode) LAN port 4.  I have tried different ports.  I have not connected it the WAN ports because I am positive that will not work.
    • Netduma-Fraser's avatar
      Netduma-Fraser
      NetDuma Partner
      It has to be a LAN port on the XR to the internet port on the AX then it will work
  • CrimpOn's avatar
    CrimpOn
    The WiFi SSID is not material to the discussion.  There is no harm in having WiFi routers that are 100ft apart having the same WiFi credentials (and certainly makes it easier to move a mobile device between them).  As long as you are aware that they remain separate WiFi routers.  A mobile device will not actually roam between them as it would between units of a mesh WiFi system.  What will happen is that performance when connected to one router will drop (and drop) until finally the device "gives up".  Drops the WiFi connection as unusable.  and begins searching for a suitable WiFi connection.
    When the Spectrum router is replaced by the XR300, does the XR300 "work"?  i.e.
    • The XR300 reports having internet access.
    • User devices connected to the XR300 function correctly?
    Interesting that the LED on LAN ports blinking red every 5 seconds is not a condition shown in the R300 user manual:
    100 ft. of Cat5e Ethernet cable is adequate for this application, provided that the cables are terminated correctly.  As the problem is described, it appears that "something changes" when the AX4 is connected to the Spectrum router or the XR300 router.  Does this 100ft Ethernet cable run directly from one router to the other, or are there any patch cables or switches involved?
