Angryasf's avatar
Angryasf
Follower
Jan 06, 2021
Nighthawk ax4 rax40 setting up issue
So I've decided to buy a router and check it out and see how well it goes and what a freaking nightmare, downloads night hawk app proceeds through set up goes to login to router using admin and the default password which is password and it keeps saying incorrect password, I did some googling and factory reset the modem, still says incorrect password. The fact I even need to post on this forum about this issue says a lot about the brand. I'm probably that one unlucky guy who brought a botched modem
1 Reply
  • plemans's avatar
    I'm not a fan of the app setup. I usually recommend people use the browser based method. it tends to go smoother easier.
    Try factory resetting 1 more time. Push and hold reset for 7-15 seconds while powered on.
    Then connect a pc/laptop to the router and attempt using that method of setup.
