Kimberlyperu
May 30, 2021Follower
Nighthawk AX4 RAX40
My fiber Optic modem went down on Wednesday. I finally got someone here to fix it. My router showed that it was trying to connect to the modem but couldn't. Before this, the internet people kept tell...
Tobi-wan
Jun 27, 2021Aspirant
What firmware version is your router running? I had auto update enabled and the 1.0.3.94 update caused similar issues to you. Sometimes it failed DHCP negotiation with my ISP, others it would say connected and retrieve an IP but I couldn't get a signal via wifi or wired. Have reset the router, downgraded to 1.0.3.88 and then done a full power cycle of fibre box and router and it's back up and running.
