gferraiolo123
Jun 25, 2022Aspirant
Nighthawk AX5 5 Stream AX4200 - Slow speed
OS 11.6.7 BigSur, Nighthawk AX5 5 Stream AX4200 / firmware is fully up to date. Every day I need to restart my nighthawk router and I believe the issue is the signal coming from my Apple TV. In the morning, I run a speed text on my laptop and it's at full speed. Then I turn on Screen Mirroring on to use my TV as a dual monitor. When I run the speed test again, my wifi speed is reduced by 80%. Once I restart my router, my wifi speed is back to normal, but I'm getting tired of reseting my router every day. Any thoughts? Btw...I've already spoke with Apple support and Optimum support and they couldn't find any issues on their end.
Optimum tends to use modem/router combo devices and not just modems.
what modem/gateway do you have from them?
- gferraiolo123AspirantI just have the modem Arris. I should also say that this set up had been working fine for about a year and then it just stopped working. There was an outage in my area, which was fixed, but that didn’t help resolve the issue. And i updated my routers firmware hoping it would fix the issue, but it hasn’t.
What arris modem is it? They much a lot of versions
- iyangNETGEAR Expert
