Kaliko
Aug 27, 2024Aspirant
Nighthawk AX5 RAX30 Wifi Stopped working however Ethernet is fine
Hey all. As of last night our wifi stopped working entirely. However, ethernet devices connected work correctly. I only use this as a WiFi router, since we have a main modem, and it taps internet for...
Kaliko
Aug 28, 2024Aspirant
EDIT: Issue seems to have been resolved, somehow?
Left it unplugged for 20 minutes, did a full reset, and it fixed itself.
- FURRYe38Aug 28, 2024Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
