Naloe77
Nov 27, 2022Follower
Nighthawk AX5400 router
Good afternoon- I upgraded to a nighthawk AX5400 wifi6 router. I am looking for help for 2 issues. 1) since I hooked this up, my LG TV keeps asking for a pairing key (it looks like for a phone) rem...
CrimpOn
Nov 27, 2022Guru - Experienced User
There are a lot of Netgear products that marketing has labeled "AX5400" by adding together some imaginary communication speeds. Please report the product number that appears on the Product Label on the bottom of the case.
With WiFi connection working correctly, your hunch is almost certainly correct. The TV is trying to pair with a smartphone, perhaps for "casting" to the TV from the phone. If you provide the LG model number, we can look in the TV user manual to see what is going on.
