Dirtnapper01's avatar
Dirtnapper01
Nighthawk ax5400 vs Nighthawk ax5300
What is the main difference between the Nighthawk ax5400 and t the ax5300? Thanks.
  • FURRYe38's avatar
    Review the online spec sheets on NG download site to see what the differences are. Probably just a slight wifi speed difference is all.
    • Dirtnapper01's avatar
      Dirtnapper01
      I went through that and seems 1.5 core on both....and  Memory: 256MB flash and 512MB RAM on AX5400 and AX5300 Memory—512MB NAND flash and 512MB
      DDR4 DRAM,  that's it??? I must be missing something.
      • FURRYe38's avatar
        Probably that and check the wifi specs between them as well. Could be same or different.
  • plemans's avatar
    What actual devices are you looking at?
    AX5400/5300 are speeds and not models.
