GROgS01
May 26, 2021Follower
Nighthawk AX5700 RAX75 Uk power I dafter please please
Hi I recently bought a Nighthawk AX5700 RAX75 from the USA. When I purchased i did some searching round and found that the power adapter was between 100v and 240v. Unfortunately it is only rated bet...
Christian_R
Jun 01, 2021NETGEAR Employee Retired
Hello GROgS01,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
