Hardware
29 Topics5Ghz wifi not working
Hi all, Im having an issue with AX6000 router. Couple of days ago my 5ghz wifi network suddenly disappeared, i tried rebooting the router but it didn't help. I've reached out to customer support and tried following troubleshooting steps: - Reseting the router to factory settings - Renaming wifi connection - Downgrading firmware and upgrading it back - Changing wifi channels - Enabled 5ghz guest network with & without security - Result: "Cant connect to this network" None of those helped. Just few moments ago i performed hard reset of the router and even though the network is now visible my devices connect to it for a brief moment and then the connection is dropped. Before hard reset i was able to connect to network from my phone but there was "no internet connection" while my laptops were either unable to connect "Cant connect to this network" or it was not visible to the laptops at all. Current firmware is: v1.0.10.140 Is there anything else i can try?Nighthawk AX5400 setup?
HI i just upgraded from the cax30 after the issue it just had and decided to not go the router combo any more as its just to much of a hassle.. i currently have a 1.2g speed plan with xfinity, my current setup is a cm2000 modem and a nighthawk ax5400 router. Im a streamer and wife works from home we have about 20 connected devices with two being hardwired with a cat8. So first i would like to know about setting up the router, i noticed on the settings and advance setting a lot of the options are not enabled by default. is there any that i can enable for a added benefit or speed gain? second im also receiving speeds of around 100/40 on 2.4ghz wifi and around 400/40 on 5ghz wifi any help would be very appreciatedRAX30 WPA3 Google Nest MIni G2 Cant Connect
Hi all, I have the RAX30 Nighthawk Router. Have had a few quirks with it, which I think I have ironed out now. I am currently running my WIFI network as 2 seperate networks. One on 2.4Ghz with an SSID and also the 5Ghz one on another SSID. I am currently running WPA2-PSK[AES] for the security. I would like to take it to WPA3-PSK + WPA2-PSK [AES] but when I have that encryption enabled I cannot get the Google Nest Mini Gen 2's I have to connect to the WIFI at all. I have tried multiple combinations of encryption and seperate bands or with SMART CONNECT without sucess. My smart light bulbs appear to have no issue connecting to the WPA3 and with SMART CONNECT enabled. What are peoples experiences with the NightHawk RAX30 and Google Devices? Thanks in advance. DwarfboysimInteresting problem connecting to routerlogin.net
Hi, I have a RAX54 and I'm able to get it setup and configured but I run into a weird problem where I can no longer access the routerlogin.net page after I've completed the setup and make a few updates. The changes that I make are: 1) switch the network to use 10.x instead of 192.x. 2) configure about 6-7 devices with static LAN addresses. 3) update the SSID names and passwords. 4) configure port forwarding and port triggering on a few items (for Fios). After I make those changes and I get connected to the Internet, I can no longer access routerlogin.net, routerlogin.com or the IP address of the router. For all, I get connection reset. If I use curl, I see this error: curl -I https://10.0.0.1/start.htm curl: (28) SSL/TLS connection timeout To 'fix' it, I can shutdown the router, unplug the internet cable, turn the router back on and I can access the UI again. Once I plug the internet cable back in, then it's accessible again. Does anyone have any suggestions for what might be interfering with accessing the start page?RAX43 5G Password Incorrect
Hello, I’ve recently been having issues with connectivity to my 5G network. I have an RAX43 paired with a Ting Fiber Modem and an EAX20 range extender. When trying to connect to the 5G network, I get a wrong password error. Occasionally, the device will connect, but the speed of the 5G network is much slower than it should be. 2.4G works fine for connectivity, but is marginally slower. I’ve verified that the password is the same for both the 2.4G and 5G bands. After factory resetting the router, the issue resolved for a few hours before persisting again. I’d appreciate any suggestions!RAX20-100NAS Q21 electronic component
Hello, I just burnt my RAX20-100NAS with a 24V power source and now main board Q21 electronic component seems toasted, and I would like to fix it. Can anyone please confirm if it is a X7DL10 component in order for me to try to buy online and change it for a new one?can't view own website
Hi, All of a sudden we can't see our own website even though the internet works fine - no changes were made to the system. The website displays correctly from other computers/phones. We didn't make any changes. ISP says our ip isn't blocked Suggestions on how to fix would be greatly appreciated NETGEAR 08 Thanx! BrianNighthawk RAX43 LAN setup issues
These are the issues so far: 1) I cannot use Address Reservation under LAN Setup in the Advanced Setup drop-down. Upon entering the device info and clicking 'Add,' I get an error 400 Bad Request This server does not support the operation requested by your client. page within the LAN Setup iframe/window. 2) It will not save my setting if I uncheck the box in LAN Setup under the Advanced Setup tab that says 'Use Router as DHCP Server. After I click Apply, the router will show me the loading bar and says it's restarting. Upon restart, the box is checked again and it does not allow me to use another device for DHCP handling. 3) The connection to the router through the browser is not encrypted and will not default to HTTPSSolvedSecurity Setup for new Nighthawk AX4200
Hola Everyone, I am RLMsDumbLovr22 (Rebecca Lynn Millwards Dumb Lover). I am in need of some assistance in securing my new Nighthawk AX4200. Just purchased this a few weeks back. I am using it for work and need it secured. My wife and I had a different Netgear product, but that product is flawed and cheated too many times to forgive or redeem itself. There seems to be an obvious pattern of the product cheating while out of town and can. It's repetitive issue dates back even before the 2015 Ashley Madison leak, in which it was involved in. Everything/Everyone has flaws but, the worst part is this particular item won't admit its mistakes. I admit I have made mistakes and am flawed as well, but I am still wanting restoration. It took a little time and some professional help from alot of people who care too much to watch me blindly be #2, but the proof is there. Now this original product (est April 2011) changes identities online often as well as physical appearance in hopes of successfully deceiving. I would attach a picture of the original product, but I'm afraid it wouldn't help because it changed appearance often, in an attempt to throw off its scent to anyone looking for answers. Who would like to help out? Thanks #enjoy🖤
