RichieRich517's avatar
Feb 25, 2023
Nighthawk AX5400 setup?
HI i just upgraded from the cax30 after the issue it just had and decided to not go the router combo any more as its just to much of a hassle.. i currently have a 1.2g speed plan with xfinity, my current setup is a cm2000 modem and a nighthawk ax5400 router. Im a streamer and wife works from home we have about 20 connected devices with two being hardwired with a cat8. So first i would like to know about setting up the router, i noticed on the settings and advance setting a lot of the options are not enabled by default. is there any that i can enable for a added benefit or speed gain? second im also receiving speeds of around 100/40 on 2.4ghz wifi and around 400/40 on 5ghz wifi any help would be very appreciated
  • FURRYe38's avatar
    What wired speeds do you see with a wired PC connected to the CM modem then with PC connected to the RAX router connected to the CM modem.
    What wireless devices do you have? Not many wireless devices will ever see anything near 900Mpbs over wireless. 2x2 MIMO devices max out at around 500-700Mpbs. Depending on there design and support. 4x4 MIMO devices can support speeds near 900Mpbs and over. Wired devcies should see near 900Mpbs and a bit over. FYI, the RAX router you have only has support for 1Gb on the WAN and LAN ports so you'll never seen the ISP 1.2Gb unless you find a router that has a multi gig WAN and LAN Ports.
    • RichieRich517's avatar
      RichieRich517
      Wired I’m getting 800/40 to 900/40 on both CM and RAX I have connected through Wi-Fi some apple products, two smart tv, nest thermostat, security cam, smart switches, and two google homes, alexa smart hub, and a couple other things
      • Kitsap's avatar
        Kitsap
        Master
        Based on your Wi-Fi and hard wired throughput, you have done a good job with your setup and configuration.
        A better understanding of Wi-Fi throughput might be in order.  A good reference document is here:
        https://www.duckware.com/tech/wifi-in-the-us.html
        Do not try to digest it all at once.  Suggest you focus first on the initial three sections.
        For consistency, recommend you use the operating system specific application from Ookla for your testing.  It avoids use of a web browser and is available in the play stores.
