RichieRich517
Feb 25, 2023Aspirant
Nighthawk AX5400 setup?
HI i just upgraded from the cax30 after the issue it just had and decided to not go the router combo any more as its just to much of a hassle.. i currently have a 1.2g speed plan with xfinity, my cur...
Feb 25, 2023Guru - Experienced User
What wired speeds do you see with a wired PC connected to the CM modem then with PC connected to the RAX router connected to the CM modem.
What wireless devices do you have? Not many wireless devices will ever see anything near 900Mpbs over wireless. 2x2 MIMO devices max out at around 500-700Mpbs. Depending on there design and support. 4x4 MIMO devices can support speeds near 900Mpbs and over. Wired devcies should see near 900Mpbs and a bit over. FYI, the RAX router you have only has support for 1Gb on the WAN and LAN ports so you'll never seen the ISP 1.2Gb unless you find a router that has a multi gig WAN and LAN Ports.
- RichieRich517Feb 25, 2023AspirantWired I’m getting 800/40 to 900/40 on both CM and RAX I have connected through Wi-Fi some apple products, two smart tv, nest thermostat, security cam, smart switches, and two google homes, alexa smart hub, and a couple other things
- KitsapFeb 26, 2023Master
RichieRich517 wrote:
Wired I’m getting 800/40 to 900/40 on both CM and RAX I have connected through Wi-Fi some apple products, two smart tv, nest thermostat, security cam, smart switches, and two google homes, alexa smart hub, and a couple other thingsBased on your Wi-Fi and hard wired throughput, you have done a good job with your setup and configuration.
A better understanding of Wi-Fi throughput might be in order. A good reference document is here:
https://www.duckware.com/tech/wifi-in-the-us.html
Do not try to digest it all at once. Suggest you focus first on the initial three sections.
For consistency, recommend you use the operating system specific application from Ookla for your testing. It avoids use of a web browser and is available in the play stores.
- RichieRich517Feb 26, 2023AspirantHonestly im not that tech savvy but I say I can defend my self well. So yesterday I’ve tried it all from repositioning the router to changing Wi-Fi channels I even tried with no devices connected to Wi-Fi and any use my iPhone 12 Pro with the ookla speed test app. Wi-Fi speeds are terrible I can only get a max of 117/40 over 2.4ghz and for 5ghz max I’ve gotten was around close to 500/40 speed. Is that really the most I can get? my old Wi-Fi router combo the CAX30 was delivering faster speeds then that over Wi-Fi. I’m considering returning product and buying the M73s mesh system in Costco and help would be great
