RichieRich517
Feb 25, 2023Aspirant
Nighthawk AX5400 setup?
HI i just upgraded from the cax30 after the issue it just had and decided to not go the router combo any more as its just to much of a hassle.. i currently have a 1.2g speed plan with xfinity, my cur...
RichieRich517
Wired I’m getting 800/40 to 900/40 on both CM and RAX I have connected through Wi-Fi some apple products, two smart tv, nest thermostat, security cam, smart switches, and two google homes, alexa smart hub, and a couple other things
Kitsap
Feb 26, 2023Master
Based on your Wi-Fi and hard wired throughput, you have done a good job with your setup and configuration.
A better understanding of Wi-Fi throughput might be in order. A good reference document is here:
https://www.duckware.com/tech/wifi-in-the-us.html
Do not try to digest it all at once. Suggest you focus first on the initial three sections.
For consistency, recommend you use the operating system specific application from Ookla for your testing. It avoids use of a web browser and is available in the play stores.
