JustDewIt
May 27, 2022Initiate
Nighthawk RAX43 LAN setup issues
These are the issues so far:
1) I cannot use Address Reservation under LAN Setup in the Advanced Setup drop-down. Upon entering the device info and clicking 'Add,' I get an error
400 Bad Request
This server does not support the operation requested by your client.
page within the LAN Setup iframe/window.
2) It will not save my setting if I uncheck the box in LAN Setup under the Advanced Setup tab that says 'Use Router as DHCP Server. After I click Apply, the router will show me the loading bar and says it's restarting. Upon restart, the box is checked again and it does not allow me to use another device for DHCP handling.
3) The connection to the router through the browser is not encrypted and will not default to HTTPS
- Which browser are you using? Have you cleared cache and cookies? I have a RAX43 on .112 firmware and do not have that problem, using Chrome as browser.
A last resort is to do a full factory reset but I'm a bit sceptical this will make the problem go away. But who knows, right?
- microchip8MasterWhich browser are you using? Have you cleared cache and cookies? I have a RAX43 on .112 firmware and do not have that problem, using Chrome as browser.
A last resort is to do a full factory reset but I'm a bit sceptical this will make the problem go away. But who knows, right?- JustDewItInitiate
I'm using Firefox, but I had tried it with Chrome...
I hadn't thought of doing that, but that should have been one of the first things to try lol. Clearing the Cookies and Ctrl+F5 to clear cache helped! Thank you
