JustDewIt
May 27, 2022Initiate
Nighthawk RAX43 LAN setup issues
These are the issues so far: 1) I cannot use Address Reservation under LAN Setup in the Advanced Setup drop-down. Upon entering the device info and clicking 'Add,' I get an error 400 Bad Request ...
- May 28, 2022Which browser are you using? Have you cleared cache and cookies? I have a RAX43 on .112 firmware and do not have that problem, using Chrome as browser.
A last resort is to do a full factory reset but I'm a bit sceptical this will make the problem go away. But who knows, right?
May 27, 2022Guru - Experienced User
- microchip8May 28, 2022MasterWhich browser are you using? Have you cleared cache and cookies? I have a RAX43 on .112 firmware and do not have that problem, using Chrome as browser.
A last resort is to do a full factory reset but I'm a bit sceptical this will make the problem go away. But who knows, right?- JustDewItMay 28, 2022Initiate
I'm using Firefox, but I had tried it with Chrome...
I hadn't thought of doing that, but that should have been one of the first things to try lol. Clearing the Cookies and Ctrl+F5 to clear cache helped! Thank you
