JustDewIt's avatar
JustDewIt
Initiate
May 27, 2022
Nighthawk RAX43 LAN setup issues
These are the issues so far: 1) I cannot use Address Reservation under LAN Setup in the Advanced Setup drop-down. Upon entering the device info and clicking 'Add,' I get an error 400 Bad Request ...
  • microchip8's avatar
    microchip8
    May 28, 2022
    Which browser are you using? Have you cleared cache and cookies? I have a RAX43 on .112 firmware and do not have that problem, using Chrome as browser.
    A last resort is to do a full factory reset but I'm a bit sceptical this will make the problem go away. But who knows, right?
