richgrace2me
Jan 22, 2021Tutor
Nighthawk AX6 AX4300: Macbook pro can detect but can't connect with password
Hi community, I have some issue with wifi connection to ask since my premium support already expired. I bought Nighthawk AX6 6-Stream AX4300 WiFi Router in August, 2020 as the second wifi rou...
- Jan 25, 2021
plemans Thanks~
I finally figured it out. I reset the router, but the problem remains.
I updates the macbook to the latest. and now I can connect to the router.
Thanks all the help!!
Simon
Jan 22, 2021Guru - Experienced User
Is the RAX45 in access point mode?
Having 2 routers in router mode can cause issues on a network.
https://kb.netgear.com/30186/What-is-Double-NAT
richgrace2me
Jan 22, 2021Tutor
No. I think I make it Double NAT.
Let me try to set it to Access Point mode and get back to you.
Thanks,
Simon
