richgrace2me
Jan 22, 2021Tutor
Nighthawk AX6 AX4300: Macbook pro can detect but can't connect with password
Hi community, I have some issue with wifi connection to ask since my premium support already expired. I bought Nighthawk AX6 6-Stream AX4300 WiFi Router in August, 2020 as the second wifi rou...
- Jan 25, 2021
plemans Thanks~
I finally figured it out. I reset the router, but the problem remains.
I updates the macbook to the latest. and now I can connect to the router.
Thanks all the help!!
Simon
Jan 23, 2021Guru - Experienced User
Never hurts to start fresh.
If its not to much of a pain, you could even try using a different ssid/password in case its an issue with the macbook not forgetting the network properly.
richgrace2me
Jan 25, 2021Tutor
plemans Thanks~
Simon
